by another_jim on Wed Jun 15, 2011 2:13 pm
For quiet, some sort of drum roaster.
For smoke, you need to rig up a smoke exhaust system composed of a flexible dryer duct, window fan, and attachment gear. The easiest is to put the roaster in a box with the front open, and the dryer duct attached to to the top, and the other end to a window fan sucking the air out. If the roaster has a special vent, you can mate the duct to that instead of using a box. The dryer duct will need to be changed annually, since it will soot up.
Most apartments have negative pressure (i.e. open the window and the air blows in), so you will need the fan to overcome it; otherwise roasting by the window will just blow the smoke in, not out. But if yours is a high rise with central AC, it may have positive pressure; and no fan will be necessary.
