by another_jim on Fri Jul 17, 2009 3:39 pm
I once thought it was true of all roasters; but I've had terrific heat gun roasts, where the ET obviously drops, so this is not true. I also doubt that there's some sort of magic going on here. In other words, I doubt that if the ET drops a tiny bit, the beans will suddenly metastasize into something horrid. My recommendation is as a policy for everyday air roasting rather than a piece of physics.
That being said, I keep trying to control my roaster on a bean temperature PID, trying to tune it so that the ET never drops. But there are always some roasts where the ET goes flat and slightly wobbly at the end of the roast. Moreover, this is more likely to happen on lighter roasts, where the effect is more dramatic. Cupping these roasts side by side with roasts where the final ET slightly rises is always no contest; the cup quality of the slightly rising ET spanks the wobbly one. So despite a "full-auto" bean PID control being much easier to use, I keep returning to running my roasts on an ET based controller.
Why is this so? I'm as puzzled as you are. If you follow a single bean in an air roaster, it circulates around the roast chamber, bottom to top and back again. In this circulation, it gets exposed to the maximum temperature at the bottom of the chamber, then travels up into air roughly the same temperature as the bean's surface, then back down. It dos this maybe one to three times a second (I've never timed the circulation rates on air roasters). So as the bean circulates, it is repeatedly exposed to falling and rising temperatures. A bean in a drum roaster experiences a similar temperature fall and rise as it moves from the lower surface of the drum towards the center and back again.
So as long as all these temperatures stay above that of the bean, it shouldn't matter that the hottest part gets cooler; the bean is always moving through hotter and colder in any case. But in an air roaster (or at least my P1) the cupping evidence is clear, at least to me: it makes a big and consistent difference.
