is there a good (+simple/convenient) roast logging tool people use for hh506ra?
here's the major features i'm looking for:
- 1. Show graph of BT/MET as the roast is going.
2. Graph width (length of minutes shown) should be adjustable... in the freebie logging tool, u can see a chart, but it's not useful as roast starts since it shows just captured data up to that moment, making it harder to see the 'shape' you are heading towards.
3. Set basic roast info like date, time, coffee, batch size, comments
4. Buttons to start/end roast, mark 1C, 2C. Dropdowns to choose current power/fan settings.
5. Show critical data points like Elapsed Time, MET, BT, Max MET, *Rates of Change per minute*.
6. Enable alerts (e.g. speech of current Time/BT/MET per set interval and/or when reaches certain 'alarm' points).
7. Save/load/print data (make smaller labels with profile data/chart to stick on jars).
8. Allow to load 'target' roast... which will show a previous graph (in dotted line) as u roast the current, so can see if u stay on track, or make a small change in desired section for comparison/learning. Would be nice to be able to offset this chart as needed... in case recovery point comes a bit later, u can shift it to still see the 2 graphs together.
I got a prototype started that does most of this, but thought maybe i should ask first if something exists already... might save me the few hours of finishing it, or get more ideas to add into it.
