by another_jim on Fri Sep 12, 2008 7:59 pm
I got an unannounced batch of the latest roast a few days ago. This is a no-no, since the package is quite likely to find us unable to check it. Abe is away, Dan is moving, and I'm about to move.
I did manage to taste it yesterday and today. There is a probably a too high MET on this roaster, since there is still a tendency towards ashy. However, this time around it, it's not nearly as bad, and a low pulling temperature of 90C or 195F, controls the problem.
The taste is predominantly chocolate. At lower doses one gets berries, at higher doses, there's an oakiness. There was a small but very distinct ferment note (sauerkraut) in the long finish of most shots, probably from the Yemen or one of the Brazils. It would rate at 4 for both body and taste without the ferment, with it, it goes down to anywhere from 0 to 3.5, depending on how tough one scores. I'm fairly tolerant of DP funk, so I'm OK with rating it a 3 to 3.5.
At its best, this blend will never get above a 4, since it's too complicated, and none of the beans would cup over 90 on their own. This is the "very good" level, what one expects from the regular blends at the top cafes. But to get out of the comfort food zone, and into the excellent zone, you'll need a simper blend that uses 90 plus coffees.
