I haven't been using the hottop B long - maybe 8 roasts. Keep that in mind. I'm using my starter 5lbs of SM ophiolite. Have got it to the point its actually pretty good. (At least espresso mistakes still make better than average drip
I haven't really noticed much in the way of smoke in the drum. Have run the fan for most of the heat build up as I had heard a potential flaw of the hottop was "flat" roasts and figure the greater air movement, the greater heat transfer. So pretty much keep it 100%.
I've been taking the heat down to 60% at the beginning of first crack, and getting around 4 minutes to second. Dumping 250g beans at 422 (rolling second) has been delicious so far.
Shorter time between first and second, even to high ET levels, had lots o nasty grassy flavors as espresso (though better in lattes than expected).
2 questions. Why put the beans in at 250? And why not run the fan during the initial warm up?
thanks!
