I broke down and picked up more than just beans on my last trip to Sweet Maria's. OK, it wasn't like the Quest jumped off the shelf into my arms, but at least it makes a better story.
Unpacking it was a lot of fun, and it is a lot smaller than I had imagined. I noticed that it seemed as though the door end of the roaster sat higher than the fan/control end, but didn't think much of it until today.
My first two roasts, with EricS' probes installed, had my senses puzzled. Things were somehow ahead of the temperatures that I had seen in
quest-m3-roasting-instructions-t15989.html, the drying phase sure smelled like it was over long before the 150-165 C suggested there. The beans looked like they were darkening quite a bit before getting anywhere close to the 190 C suggested as a pre-1C switch-over point, but maybe that was that I had let the MET get too high. Sure enough, the first pops of 1C were at 167 C (indicated). Second crack hit around 188 C, and I dumped at that point.
A second run with the same
Panama bean let me better control MET, but sure enough, 1C first pops were around 170 C again, with the roast stopped around 178 C. By inspection and smell, it is somewhere around FC, with the beans starting to round and smile a bit more.
So, I'm puzzled. I checked the positioning of the BT thermocouple and it wasn't bent and was within a couple mm of the drum's internal struts, but not striking them. I checked that my meter was set for type K to match the thermocouple, and that I was in Celsius mode both on the meter and in Artisan. I checked the BT thermocouple against a type T that I have in boiling water, as well as a Thermopen, and all were within about a half a degree C from 100, which makes reasonable sense.
Could it be that the roaster's angle (~6" from the front screw that mounts the legs to the drum to the counter, but ~ 5 5/8" at the back screw) is keeping the 150 g charge of beans further back in the drum and not covering the thermocouple? I do get beans in the trier and see them against the window, so it isn't that they don't move up to the front at all, but...
Any suggestions would be greatly appreciated. I don't expect to replicate anyone else's temperatures, but I wasn't expecting to be something like 30 C off.
