by Why1504 on Fri Apr 08, 2011 9:06 pm
To clarify, the Quest M3 is the best roaster I have ever used.
I also use denatured or isopropyl alcohol for the fan and tight areas. When you purchase, check the percentage. Walmart sells 70% it sucks. Some pharmacies sell 85%, 90%, and 98%. 90% works well for me out of the bottle.
This stuff is a GREAT cleaner for this type of application. It will not leave any aftertaste. It sanitizes through evaporation. As a general rule it is safe for the surface you are cleaning. When I had my Behmor I used alcohol to clean the inside. It did a quick great job. It would cut the goo fairly quick.
I have just began to use the dryer sheet under the chaff screen, I am not sure just how effective this is. But it does catch some of the sticky goo.
Cooling with 300g is a issue for me too. I am looking to construct a bean cooler as well. I am thinking a small fan and a colander. place the fan over the colander turn it on let it blow. Stir. I have also considered taking a box fan and mounting a fine screen on the suck side with wood sides. lay the fan blow side down on blocks of something, pour the beans in turn it on. This may be overkill but I expect it would shut down a roast quick. I do agree a external bean cooler will allow the roaster to focus on roasting.
