by another_jim on Thu Aug 04, 2011 11:26 am
I disagree. It is like any other convection process. If you keep the drum temperature the same, going from low to high airflow speeds up the roast. Anything else is not physics, but magic.
I basically keep my drum temperatures fairly constant between 450F to 525F throughout the roast (exact temperature depending on bean and profile), and slightly regulate the roast speed by altering airflow. Raising airflow speeds the roast, but requires a simultaneous increase in the heat to keep the drum temperatures constant. The fan on the M3 is not powerful, so the effect is that a max airflow roast of 150 grams is about 2 minutes faster from drop in to first crack than a min airflow roast (fan just barely turning, around 3 - 3.5)
