Propane pressure
Question to the brainiacs. I have a 1kg propane roaster I have purchased new from Turkey. From the day one it took long time to worm up and roasting temp. remained low during the roast, I stopped using it and concentrated on my Sonofresco. Today I decided to go back and try it again.While vacuuming chaff from the unit, Iv noticed a pressure regulator inside the machine. The propane hose from the tank already has a regulator.Could the fact that there are two regulators be responsible for lower temperature? Your expertise is much appreciated.
Did the regulator on the tank come with the roaster? Is the 'regulator' in the roaster actually the adjustable gas flow valve? I think we need more information here. Maybe give the make and model and someone here may have specific advice.
Some speculation and general info: The raw (unregulated) pressure from all propane tanks is from about 100 to well over 300 psi, mostly dependent on the temperature. Regulators cut this down, depending on the heat to be produced. Those for a BBQ run at about 0 to 6 ounces and cannot produce more than about 35 to 45 thousand BTU of heat. Those for large smokers produce 0 to 20 psi (i.e., way more heat). If the regulator did not come with the roaster, and if it is a typical BBQ regulator, then that's your problem on a large roaster. On my home made air roaster the smoker regulator gives the coarse adjustment, then the needle valve on the roaster gives the fine adjustment.
Another issue is dirty propane. It is not uncommon for crud in propane tanks to clog a regulator, especially the smaller ones like on BBQs. If you use little 1-pound bottles they are filtered, but if you use a refillable tank, you should have a filter installed between the tank and the first regulator, as refillable propane cylinders do not get filtered propane at most filling stations.
- Boldjava
Have you contacted manufacturer? What did they say?
LMWDP #339
LMWDP #339
- JK
Are you sure they are both regulators or is one maybe a shutoff valve?
I'm on a Mission from God!
- drgary
If you have inadequate propane flow you would also be able to recognize it by not being able to turn up the flame sufficiently. In my 1 Kg roaster I can see the flame. Can you see yours and does it look like videos of your roaster at the manufacturer or a dealer, working properly?
LMWDP#308
LMWDP#308
- JK
Two regulators is ok but is there a way to adjust heat during the roast?
- erics
- Supporter ★
The gas pressure regulator inside your roaster is a second stage regulator. The first stage of regulation takes place at your propane tank.
It would simply be my GUESS that the first stage regulator is reducing the pressure BELOW that required by the one in your roaster since you have stated that the problem existed from day one.
It is time to either read the manual that came with your roaster or contact the mfg (as others have said) as regards the required input pressure to the roaster. And for all of this, it is time for a licensed individual to measure these pressures, i.e. not recommended as a "do-it-yourself" project.
- drgary
+1
That roaster looks extremely capable (and beautiful). I'm sure that once you've got it set up you'll be able to control it very well. I say this because it has the kind of design of similar 1 Kg roasters like the North, where you can vary heat, airflow, and probably drum speed. I would be surprised if you can adjust the gas by hand in some way. Can you show us a close-up of the control panel? I'm interested in seeing what those blue knobs do.
+1
LMWDP#308
LMWDP#308
