noah wrote:Question: When planning out a roast profile, how can I go about subdividing the roasting phases to refine my profiling? For example, how can the phase from the start of first crack to the start of second be subdivided according to the results in the cup?
Are there any notable subdivisions to be made with any of the other phases (either after the start of second crack, or from 300 to the start of first crack)?
I'm a strong believer in the "KISS principle," which of course stands for "Keep it simple, stupid
" I see no point in introducing needless complexity when none is called for.
Therefore, I would divide up the roast cycle into the following, notable landmarks and periods:
(1) Charge Temperature (e.g. what is the temperature when you drop in the beans?)
(2) Drying phase -- this is the first part of the roast and begins with charging the roaster and ends at roughly 300F, depending on how you measure it
(3) Pre-First Crack
(4) Initiation of First Crack
(5) Period between initiation of First Crack and end of roast, if you don't roast into 2nd Crack
(6) Initiation of 2nd Crack, if you get that far
(7) Duration of 2nd Crack, if you get that far
(8) Termination of Roast, which may follow either 5, 6, or 7, above
With the proviso that stalling the roast at any time is inadvisable, the goal is to increase temperature at a relatively constant speed (which will differ during the phases) during #s 2-7, above. As a general rule, you will go relatively slow in the drying phase, faster in #3, and fairly slowly from the initiation of 1st Crack (#4) until the end of the roast.
In more direct response to your specific question in the first paragraph, I'm unaware of the particular importance of any specific part of the period between the onset of 1st and the onset of 2nd, however the overall duration is very important. With regards to the question in the second paragraph, stuff happens very quickly after 2nd crack begins, and unless you have a particular goal in mind or you like very darkly roasted coffee, you are probably not going to be going very far into 2nd in any event. All you can do is to time how long you have been in 2nd crack, and follow the temperature changes. These two things, easily measured, are the most important.
I have not heard of any subdivisions of the time after the drying phase until the start of 1st crack, although towards the end of this period you need to watch the amount of "heat velocity" you are carrying into 1st crack. If you are still adding lots of heat just before 1st crack starts, the roast will have a tendency to "get away from you," e.g. to progress at a very fast rate making the control of the period between onset of 1st and the end of the roast "too short," and hard to control.
ken
