noah wrote:
Also, can a roast go too quickly through the 300-400 stage?
Yes, you can BURN the beans during this phase. I've had a couple of batches of beans where I really pushed the flame height on my drum during this phase, and the coffee tasted "burned." Jim S. happened to visit me recently when I produced such a result (with a batch of Wondo Bonko). We learn from our successes as well as our failures, if we pay attention. And it wasn't obvious to me that this was the cause of the burned batch, until I gave it a lot more thought during a subsequent roast session. Ever since I have been more careful not to overdo it during this phase, just to get to first crack at some arbitrary number of minutes. I'd rather be a minute "late" if I get behind, then to push the heat up so much and so fast (just to make the time landmarks I shoot for), since being "late" might flatten the coffee out a bit, but it won't make it undrinkable. Burning it will make you toss the coffee in the trash, unless you are like a few friends of mine, who can and do drink anything . . . .
noah wrote:While the exact progression of compounds may not be able to be mapped, cant we generalize along the lines of, for example, from 400-430, you have the best chance of maximizing acidic fruitiness, from 440 on, chocolates, etc. The general principle of 300-400 gives bready, nutty, and 400 to second crack gives chocolates is well known. But cant we further break this down, or is it so bean dependent that it is a fools errand?
First, you'd have to decide on whose "400-430" you were talking about, since any of these arbitrary numbers will mean very different things depending on your roasting equipment and where your temperature sensors are located. I think it is possible to think too much about this sort of thing. Most people will learn more about roasting if they keep things relatively simple. Initially, it is most important to learn how to identify the cracks, and to become comfortable with the changing appearances of coffee beans as they roast. As one becomes more accustomed to using a particular piece of roasting equipment, one will learn to correlate the measured temps (wherever they are being measured) with what is going on in the beans in the roast cycle. At this point,
your "400-430" will hopefully mean something to
you, even if they are just abstract numbers to
me. Finally, you will achieve some sort of routine (to which Jim alludes in his own personal roasting approach) with which you are comfortable. You can then take that routine and apply it to different beans.
As an example, I roasted 3 coffees this afternoon, a total of 6 batches starting out with a pound of green for each. The coffees I roasted were Ethiopian Worka, Ethiopian Wondo Bonko, and a Bolivian Cenaproc I bought from the Coop 6 months ago. All the roasts took approximately the same total time (roughly 15 minutes), however the Cenaproc was roasted much darker, in the same total time. I know from experience with my roaster and where I have my probe situated in the drum, that 2nd crack will start within 1/2 a degree F from 435F. I roasted the two Ethiopians to 433, and the Cenaproc to 439. I did this because I have roasted these coffees before and have learned from prior experience with them. Although I generally don't like to roast into 2nd crack, I have learned that the Cenaproc is simply unsuitable as a single origin for espresso at a lighter roast level -- it needs 20-30 seconds in 2nd crack to be usable. Even then, if I had it to do over again, I'd probably not have bought the coffee, but it does serve a purpose as a counterpoint to all the Africans I drink most of the time.
To get back to your second paragraph that I quoted, you could try to apply the same logic to choosing wines, but I think you will find it similarly useless, from a practical standpoint. You would probably be much better off finding some flavors that you like in coffee, then trying to achieve them by the beans you choose to purchase, and the results you can easily get by varying simple parameters such as overall roast time, length of time between the cracks, and the final temperature (point in the roast cycle) that you roast to. Molecular approaches, although intellectually satisfying, seldom will get you anywhere with coffee, whereas relentless experimentation with simple stuff will usually point you in the right direction.
ken
