another_jim wrote:This is electrically unsound, since the cord should drop enough voltage to feel warm to mildly hot to the touch, otherwise it isn't working -- just make sure the plugs don't get smoldering hot.
I agree. The only way to do that is to have a cord that is used over what it is designed for. A popper is around 1200w. On 110V it will be 11A, on 230V it will be 5A. So take a cord that is under. But it means that you are also taking a risk of fire. Note that the fan will go slow if you drop the tension. This is due to the design of it. The resistor is cut in two parts, and the engine is plugged at one of the part so it takes around 20V. This is a continuous engine, which means the speed is function to the tension. If you reduce the tension, you reduce the speed, you might increase the temperature.
You also might discover that the temperature suddenly drops if you make the popper work more than 10 minutes. It will depend on the popper. There is a bi-metallic contact as security. And once it is dropping you cannot do nothing that wait for the popper to be cold. You can throw your batch away. You can disable the contact, but it is also a risk of fire. You cannot just weld it with tin as the temperature there is close to the melting point of tin. You need to attach it with a piece of cable.
