Phidgets 1048 and Artisan setup
Hi there. I just was having problems setting up Artisan and the Phidgets 1048.
I have 2 thermocouples set up, but I'm getting an error in Artisan that says this:
Does this ring a bell for anyone? What more info can I provide.
This is V.9.4 running on Mac
19:07:27.610 Exception: PHIDGET1048temperature() dlopen(/Library/Frameworks/Phidget21.framework/Versions/Current/Phidget21, 6): image not found@line 25263
I've installed it on two different devices both macs no problem...if you have not installed driver yet they are here http://www.phidgets.com/docs/OS_-_OS_X#Quick_Downloads
also need to go to configure/device... select meter and from dropdown menu to right select phidget 1048...I hope that helps
