Phidget 1048 giving me wrong temperatures - solved - Page 2
- drgary
It could be significantly less expensive. That isolator looks pricey but whatever will fix it, right?SJM wrote:Hmmm....I think that would be more complicated and not significantly less expensive than buying an isolator.
LMWDP#308
LMWDP#308
Thanks to everyone but SPECIAL THANKS to Steve Green who helped me figure out the problem.
The problem is in these:
http://www.phidgets.com/products.php?product_id=3106
The Huky came with thermocouples with mini plugs on them and instead of just going with my original plan and just taking them off, I ordered these which basically just convert the plugs back to bare wires.
Anyway, taking the original plugs off and simply inserting the wires into the Phidget ....works.
Now to return these unnecessary plugs...
- drgary
Now that's way less expensive!
LMWDP#308
LMWDP#308
Couldn't have done it without the resources of H-B for which I am once again indebted and grateful !!!
Susan
Susan
- boar_d_laze
Homage for Ohmage.SJM wrote:Couldn't have done it without the resources of H-B for which I am once again indebted and grateful !!!
Rich
Aw shucks, Ma'am. If I helped, it was probably mostly a case of "blind squirrel finds acorn."SJM wrote:Thanks to everyone but SPECIAL THANKS to Steve Green who helped me figure out the problem.
Seriously though, thermocouples are comprised of two wires of a specific alloy. I suspect your connectors didn't match those alloys properly. It's the same problem you often encounter trying to daisy chain your PID thermocouple to your Phidget or other logging interface. The wires need to match for it to work.
I was thrilled to hear you got it working. -and thanks for the call.
Steve
