I have been avoiding this cleaning thing for some time until I noticed that a strong smell of something being burnt started being emitted lately when I turn on the roaster (which I later discovered was because of a pile of burnt chaff below the drum). This made me decide to clean it especially that the signs of filth in different parts of the roaster were quite apparent (I must admit that I enjoyed not taking care of the roaster and roasting most the time, this was quite fun and I enjoyed doing it). However, the cleaning experience was an utter nightmare, that is to say, I am honestly terrified to roast again because of what I have seen in the cleaning process. It took me three whole hours to clean it, which was not even enough, so I simply stopped at the extent where it was simply impractical to go any further with the cleaning. The roaster was nearly fully taken apart, which I thought was totally "wrong". Therefore, I think that I must take precautions against it getting that dirty again because I am not going to do this madness again.
I used an instant oven cleaner spray to clean the metal plates and the metal parts that I was able to remove from the roaster, which was very effective (though quite harsh and irritating to eyes and hands so better be used with enough ventilation and using gloves and a mask). On the other hand, for the fan cavity, which was the only part of the machine that I did not disassemble (otherwise I would have fully disassembled the roaster), I used a piece of cloth, a good quantity of rubbing alcohol and an hour and a half of hard work using a tooth brush and too many cotton swabs.
This is also a good opportunity for the other members to have an insider look into this roaster, which is why I was generous with the photos.
I don't know what caused this, and whether it was something I did. I have this change in colour only on one side, right below one of the two heating elements (the one to the right).
Arpi: this is the first time I disassemble this beast. I would like to share with you that the best way to put the drum back into place is with the front plate of the roaster is facing upward (as shown below), since you can easily see the joining of the shaft with the motor through the front door (which is shown opened), note that it is best to fasten the funnel only afterwards so that putting the drum back will not be a two-part puzzle of fitting the shaft and the tube in the same time. This took me much time to figure out.
