There are many variables that are location specific such as ambient temperature, air currents, line voltage, unit to unit variation, etc. that make direct transfer of parameters problematic.
I don't have the B [ See
UberHotTop ], so only general principles apply.
- check line voltage for consistency. If it varies, so will your roasts. Consider a Variac.
- don't overload. 225g works well
- install a bean temp sensor. See Randy G
Add Bean Temperature Monitoring to the HotTop- drop the beans around 250° BT
- reduce power input rather than increase the fan speed to extend time between 1st & 2nd cracks
- start lowering power input around 365-375°F BT to 80%, 70% @ 1st, 60% @ 415°F *
- use a small desk fan to cool more quickly
- make notes of EVERYTHING
* % values based on variac voltage applied to heater. HotTop power levels may not correlate precisely.
