Here are the results!
The test was successful this time in terms of differentiating the cups. It was a lot easier to taste once the cups got cold (from initial 212F). The flavors popped out and there were big differences. There were no defects. I modified the grind setting to 7, which in a previous test, gave me the most acidic flavor without encroaching in bitter territory. The blue berry muffin flavor was prominent during grinding. I also use a slightly higher dose to brew ratio this time.
There were noticeable differences between the different roasts. However, the differences inside each roast were more subtle (but still different). It is difficult/impossible to tell which one is best unless I were looking for something in particular a priory. There was a huge range of flavors.
Inside each roast, I could taste a difference in acidity, especially from first sample to last. There were differences in the "flavor spectrum". The last cups (sample at the end of each roast) had the lowest frequency, meanwhile the first cups were the brightest. Depending on your mood, you could like the higher spectrum better, or it could go the other way.
Ethiopia Amaro Gayo Roast Sample flavor test
First batch
147+125 = 272 grams
Event N Time BT
1 14:10 402.4
2 14:55 398.3
3 15:35 398.6
4 16:15 400.2
5 16:55 403.0
Second batch
141+122 = 263 grams
Event N Time BT
1 15:19 408.2
2 16:02 403.2
3 16:39 402.7
4 17:09 404.2
5 final roast sample
Third batch
140+144 = 284 grams
Event N Time BT
1 11:25 432.8
2 12:24 444.1
3 12:59 431.7
4 13:34 423.4
5 14:09 420.5
Conclusion:
I wasn't able to tell which one was best. But this test helped me get familiar with flavor changes during the final phase of the roast. Of the three roast styles, personally, I would pick the first, followed by the third. The second roast had the most "premature" flavor. While it had the most blueberry, the other premature accompanying flavors brought down the overall appealingness. The second roast was my past idea of how light roasts always taste. The second and third roast were more boring. Inside the first roast (remember this is for drip), I would pick the first (14:10) for its most peculiar/distinctive/attractive taste in drip. But I know this is a subjective maybe temporal opinion.
Cheers
