Ken Fox wrote:The other issue with a flow meter, which is obvious but which I did not consider before, is that the propane or nat. gas must flow through it, in order to get a reading. This creates some plumbing and ergonomic issues.
If one puts the flow meter directly in-line, in the gas flow path, then the gas piping will either have to be made somewhat circuitous, or the meter will not be placed where it can be easily read.
You are correct when referring to the particular type of flowmeter in the picture, which is called a "rotometer." I thought it was an appropriate choice because it is simple and inexpensive. Not only must the meter be inline, but it must be mounted vertically, and the gas must enter at the bottom and exit out the top. This means, as you say, that the gas piping must be designed to accommodate it. Really this is trivial to accomplish, but takes a little extra effort and costs a little more.
Also, because the rotometer depends on the earth's gravity in order to function, this flowmeter would be a poor choice for roasting on the International Space Station. Roasters on the moon or Mars will have to recalibrate their rotometers in order to hit their waypoints properly (which is the least of their problems, actually).
With respect to ease of use, there are other types of flowmeters that are two part devices: a sensor in the gas line, and a remote readout that can be located anywhere. But these are more expensive and more complicated, and I know how you feel about engineering complexity....
Ken Fox wrote:If the idea is to be able to roast coffee while referring to the flow meter to guide the roast, and if one doesn't want to continually contort one's body to know the gas flow, then the gas piping must go up to eye level, pass through the flow meter that is located there, then the piping must go back down to where the control valve is located, then out to the burner.
I was under the impression that you didn't refer to your pressure gauge continually throughout the roast; I thought one referred to it only a few times when a change in the heat output was deemed necessary. It would seem to me that the contortions about which you speak would occur at a tolerable frequency; a mere one or two chiropractor visits a year should suffice to iron out whatever kinks are produced by flowmeter contortions.
Ken Fox wrote:Since, as has been pointed out previously, if one has a fixed orifice size for the burner, the heat produced/consumed/ flow of gas will be proportional to the pressure, one can see why the manufacturers have gone this route with pressure gauges, rather than to install flow meters
Manufacturers are keenly (kenly?) interested in reducing costs, otherwise they wouldn't be able to send their kids to college. So for them the pressure gauge, rather than a flowmeter, is functional and cost effective.
As with a custom tamper, however, Kendall, Jon, and all the rest of us are free to spend a little extra on a fancier gizmo if it gives us satisfaction. Or if we think it makes the job easier. It is not necessary to justify the expense to you or anyone else...although that may not be true for those folks who are married.
