by cannonfodder on Wed May 11, 2011 9:31 am
I have the old D model. Got it directly from hottop many years ago. With the viewer's choice coffee project on HB I have had a pretty steady supply of coffee and have not roasted for some time. In fact, I have not purchased greens for quite some time. With my out of state move, two new jobs, new house, etc.... the past few years I have not had time to do much. Most of my coffee is vac packed and in a deep freeze since 08/09 but I have picked up a couple pounds now and then since then.
I thought about getting the upgrade controller to update the machine to the P model but don't want to spend the $420. In fact, I think I spent less than that on my roaster years ago. My roasts have been bland, borderline baked lately. The time to 1st has been slow with the transaction to second being very quick. The roasts lack complexity and sweetness (even with new beans). The roaster is in good order and well taken care of although it is very well used. I also run it on a dedicated 20 amp circuit so it has plenty of power. I have removed the filter from the back completely to increase the air flow and I have used removing (or rather raising the rear filter) along with cracking open the chaff tray as a poor man's damper/airflow control but again, the 1st to second can range from as little as a few seconds to 2 minutes but is very erratic which is why I want more control. I pulled it apart Sunday to clean it out and it was not very dirty to begin with. I am more than capable of making the mods but have been tempted by the Quest M3 but having a perfectly good drum roaster right now I cannot see spending the 1200 on another one.
My end goal is to ramp up the charge to first crack time and extend the first to second which is why I was looking at the fan control. I could bypass the machine control and leave it off to speed up the charge to 1st times then slow the roast from 1st to second by increasing the air flow through the roaster. My batch sizes can vary from as little as 70-80 grams and as much as 230 depending on the blend I am roasting.
