Version 0.1
I'm in the prototype phase of making a Milk Can Roaster. The milk can is stainless (5 liter). I made a stainless shaft, coupler and stainless perfed vane on the inside. I've only done two roasts using a heatgun as the heat source. It does 1.5 pounds nicely. Very even roast, no burnt beans, tipping etc.
Once I roast another 20 or so batches I'll use real bearings and a motor. Right now I'm getting the feel of it. I may also change to a propane stove burner underneath for all or most of the heat. I don't know how well that will work. [Edit: I like my wood bearings just fine! The propane burner works very well! - see video below.]
The inside vane is tilted so that the beans in the back are spilled towards the front and the unit itself is tilted so the beans in the front slide to the back.
Any suggestions would be welcomed. Entire budget for this will be less than $100. I was thinking I'd have to punch some holes in the side, but that doesn't seem necessary at the moment.
Update:
I've switched to propane as the heat source, but I haven't had enough experience with the machine to do a good job of controlling the roast. With the heat gun, everything was smooth and controllable. With the propane burner it wants to get hot too fast. I'll do a few more batches and try to creep up on it a bit.
[Update] It is easy to control the heat/ramp/profile. I just needed a couple batches to get used to it.
I also got tired of cranking the drum by hand. Couldn't keep notes and watch the roast etc. at the same time. So, I hooked the drum up to my Tormek knife sharpener. It turns at 90 revs/minute. Once I get the temperature dialed in better I'll have time to sharpen a knife or two before it gets to first crack...(yes, I'm serious). I could be wrong, but this might be the first time in the history of coffee that a roaster and knife sharpener were combined.
Here is a video of the roaster in action.
http://www.youtube.com/watch?v=QBSeh69h2_I&feature=channel
Here is a video of the cooler I have, which is actually incredible and useful for all roasters.
http://www.youtube.com/watch?v=S2mRgPpIFxA&feature=channel
Yes, I have sharpened knives while roasting. It takes about 2 or 3 minutes to sharpen a knife razor sharp, and I'll do it during the first few minutes of the roast. After that, no way!
dan
