Moved the cheap meter to another bag, vacuum sealed it, and after a couple hours it stabilized on 51%. The exact reading of the 1st bean bag was 39% vs 51% for the 2nd bag. So this method, even with my pathetic meter, seems to give some indication of bean moister content.
The meter I use has some spiral of metal attached to the back of the dial pointing at the RH level. I don't think there's a cheaper, older, or worse meter you can buy. It looks something like this, but not exactly, I also couldn't locate pictures of the backside where you can see the metal spiral used to measure & indicate RH.
Guys, this is an extremely easy method to try and if you only have zip bags, just throw the meter there and draw out as much air as you can and see what numbers you get. . . . .
and report back!!!farmroast wrote:On the first page of the thread you linked I did a drying/weighing process that has continued to work well when needed.
I saw that process earlier, but it's too much work and sacrifices too many beans. If the one we're talking about here gives a relative indicator, it should be enough for us home roasters.
