by boar_d_laze on Sat Aug 06, 2011 11:13 am
08/06/11 Update
At four days post roast, this blend is still maturing.
First Pour:
First pour of the day was ground on same grinder setting as yesterday's last -- the first pour ever with this coffee. Most obviously, today's first pour was extremely slow, even though made without pre-infusion, while yesterday's was "normal" (not to mention good looking).
Additionally, the grinder is controlled by a timer which, for today's first pour, was also on the same setting as yesterday's. The first pour was overdosed at 18.1g (Strada basket).
Because I was planning to weigh the extraction, I allowed for the extra time involved in taring the cup and took a longer cooling flush than usual. Too long.
Naked portafilter. Some spritzing and channeling. Slow pour (as already said) took awhile for the stream to come together. By that time it was already light. Crema too light. The whole thing was a "free pour" using the semi auto button so there was no question about stopping when things got really ugly.
Extraction: 30.0g
Nice sweet aroma, chocolate and florals, more florals than yesterday. Tasted like crap, and bitter as my second ex. Sinked it.
Talk about one thing after another. This pour is a data point on the bad technique curve, but not on this coffee's.
Second Pour:
Adjusted the grind coarser. And another thing... Grinder runaway inadvertently started when adjusting time. Whatever. Dosed at 16.2g.
Normal brew temp (probably 200F ish). Used pre-infusion and the "volumetric" double button (set to 80ml). Good looking naked pf shot, which came together quickly. The machine cut the extraction at the same time I moved the cup out of the stream. Yield was 32.4g (exactly double the dose, interesting coincidence)
Crema appearance was perhaps slightly on the light side, but still good.
Same aroma, some complexity to it, more florals than yesterday. Same notes as yesterday: Apricots; Berries; Caramel; Vanilla; Milk and Dark Chocolates. Finish is dark chocolate with dried apricots. Medium body (as you'd expect from a full-bodied blend pulled 2:1).
God shot? No, but very good.
Third Pour:
Dose = 17.3g, Extraction = 30.2g
Notes: Same as before but with more body. I thought there might have been a very slight tilt away from lungo to ristretto, with just an RCH of earth and funk, but am chalking that up more to knowing the exact dose and extraction weights rather than any real difference in the cup. Very pretty crema.
God shot? No, but slightly closer. 9/10
Fourth Pour:
Dose and Extraxtion -- not weighed. But dose was timed at same timing as the 3d pour, and cup was pulled with a (probably) slightly lesser extraction weight.
Switched portafilter to a regular, single spout with a different (but extremely similar) double Strada basket.
Notes: Pulled shot with slightly darker crema. More body. Sweeter, richer. 9.5
Nearer my God to Thee.
Preliminary Conclusions:
Too bad the runaway timer wasted a couple of baskets worth. This is a very good blend, too good to throw away. The Klatch beans are excellent. Just as greens, they're better than the Roastmaster beans I've been using lately. In fairness, poor storage of the Roastmaster stuff might be a contributor; and a few of the beans have netted some very good cups, e.g., CR Sin Limites Honey.
Back to "Conversation..." I've got 1/2 a hopper left, as well as another 190g roasted on 8/4, in the wings, and will roast one more load -- alla time same same -- later this morning. So will be playing with it, more or less "as is," for the next few days.
I can't help but wonder what it would be like without the Bob. I.e., 60/40 Bosco/Covadonga.
The roast program and timing to FC were appropriate. Neither more nor less roast artifacts sounds attractive. It would be interesting to try something faster and more nimble than a HotTop Programmable; but...
Overall, K Conversation plays in the same league as SM's Monkey and Lenny Dee blends -- without being quite as sweet or as "blendy" as either; but a little more New World, a little less Italian. Call it PSW.
It's too soon for final conclusions regarding this particular blend or Klatch greens in general. But at first blush Klatch is a top notch supplier, and the "top notch" applies to K Conversation as well.
Both merit further exploration.
BDL
PS. Your comments are welcome.
