I did a lot of profiling experiments when I was getting up to speed on the Quest M3 (QM3); I did even more when I was designing the ramp controller for my air roasting set up several years ago. These profile comparisons showed that very small profile differences made for very distinct differences in taste.
This variability was borne out in the roasting competitions, where entries using the same coffees, roasted to the same level, sometimes even on the same roasters, tasted very different.
So if small profile changes make for big taste differences, what are the chances of getting indistinguishable tasting coffees from two completely different roasters (machines), using completely different profiles? You'd think there is no chance, instead it can be close to a certainty. All you need is that the same roaster (person) does the roasts to suit his or her own tastes.
After not using the air roaster for a 18 months, while learning to use the QM3, I decided to do a comparison between the two machines. I wanted to prove to myself once and for all how much more interesting and complex my QM3 roasts tasted, and that I had spent the grand for the roaster wisely.
I roasted two brew coffees, one light, one dark, and two espresso SOs, also one light and one dark. I did this set of four roasts on both the air and drum roasters, using my favorite profiles (10 min for brew and 11 for espresso on the P1 air roaster, a few minutes longer and much more seat of the pants on the QM3 drum). I did not attempt to make the drum roast look like the air roast, instead I stopped the roast when it looked and smelt right. I was not trying to produce identical roasts, I was trying to produce the best possible roasts from each machine.
The light brew and espresso coffees tasted indistinguishable. The dark air roasts, both brew and espresso, were a hair more aggressive on the roast flavor, but so close it took several tastes for me to be sure I wasn't imagining it.
How is this possible? Simple. I obviously have a desired taste balance in mind, and my belief that I've mastered the roasters and gotten the best profiles simply means I can get that desired balance on any coffee I roast on either machine. So roasts from the two roast machines taste the same, since they both closely approximate an ideal I have in my head.
This means that profiling advice, at least mine, is probably quite subjective beyond a certain point. There are certainly incompetent roasters (people) and hopelessly bad roasters (machines). There are probably profiles that are simply too fast or slow for anyone's taste. But within these limits, it is the taster's sense of what is a good balance of flavors, rather than anything more measurable, or anything about the roasting equipment, that determines how ones roasts will taste.
For instance,
Ken Fox's thread mentioned that Stephen Diedrich advocates a "slow start/fast finish" profile that is slower to the first crack and faster thereafter than the one Ken normally used on his previous drum. Ken spent a long time developing that profile to suit his sense of taste; so unsurprisingly, he thought the Diedrich profile was not as good. But other members who tried it liked it better than a "fast start/slow finish" profile.
So while it's probably a good idea, as a new home roaster, to start with a proven profile until one is comfortable controlling the machine; after that one should try a range of different profiles and compare.
