by Arpi on Wed Aug 03, 2011 8:44 am
Hi all.
Bean size and shape could be important to the development flavor during the roast. A larger bean would have a larger gradient of temperatures between the center and the surface of the bean (measured as BT). This difference could add to a large range of flavors.
Same could be said about its density, which would affect the speed by which the center of the bean heats up. The center of a high density bean would heat faster (higher heat conduction).
These two factors would affect the choice for the best roasting profile. For example, the center of a small bean size would heat up faster and would have a shorter maillard reaction. If the roast time were long, then the flavor could get negatively affected (overcooked). On the other hand, the center of a bigger bean would take longer to heat up and maybe it could take a longer roast time without much penalty. But if a bigger/less-denser bean had a short time, then flavor in the center of the bean would not develop. In between the center of the bean and its surface, there is room for various stages of flavor. The surface temperature can be measured and the inner temperature could be estimated during a roast.
During a roast, there could be a best compromise of surface/inner temperature to give the best overall flavor depending on the density and the size of the bean.
Density can be measured. The size and shape can be categorized. For example, the Kenyan beans designation for size and shape is:
AA
AB
PB
C
E
TT
T
UG
I am not sure if the Kenyan bean system could be used for other beans or not. Is there a system that can be used for roasting?
Cheers
