How to roast dark without ashy flavours?
Hey team,
Writing hoping someone can help me out with tips regarding "dark" roasts.
Up until now I've always done roasts around 30 seconds after first crack hoping to maintain origin characteristics.
I'm thinking perhaps it'll be better for some milk blends to be roasted darker than this but I'm finding anything I do that goes much darker or anywhere near 2Nd crack turns out super oily and very metallic/carbony/ashy/dirty in the cup.
Does anybody have any tips for me. I will attach a profile of one of my darker roasts to examine.
Thanks in advance.
Thanks in advance.
- JohnB.
I don't know why you would have "super oily" beans if you are dropping the roast prior to 2nd crack. Most of my roasts fall in the City+ -Full City range so no 2nd crack & no oil. Even my Full City+ roasts which run 5-10 seconds into 2c seldom show any oil.
LMWDP 267
- another_jim
-- Drop your environmental temperatures. They should not exceed 260C/500F
-- There's a zone between the time the 2nd crack starts and it when it gets rolling when a lot of coffees develop a very funky, earthy smell. Either drop your roasts ahead or behind that period; not during. The smell isn't in the brewed aromas, but the roasts in that zone have lousy caramels and taste somewhat ashy, flat, papery, etc. The caramels get tastier later, when the 2nd crack is rolling.
Jim Schulman
Given the roasters you own, I'm probably not in your league, but here's my take on it. First, a few questionsI'm thinking perhaps it'll be better for some milk blends to be roasted darker than this but I'm finding anything I do that goes much darker or anywhere near 2Nd crack turns out super oily and very metallic/carbony/ashy/dirty in the cup.
- Which roaster, your Has or your Bella or both? If it is only one roaster then you've got a clue about whether it is machine related.
- What coffee bean, or is it several? Again, here we can perhaps narrow it down and see if it is related to a particular bean or maybe a bad batch.
Now for some uninformed opinion
- John is definitely onto something concerning the oil. At the stated degree of roast there should be no immediate oil. Immediate oil only occurs with extremely dark roasts (Eventual oil is a sign of old roasted beans). This makes me wonder how you are judging the degree of roast. Most of us with tiny roasters go by the sound. But, with experience, and with big roasters and automated roasters, eventually we go by the temperature. (Even with my little Quest M3 I'm increasingly looking at the temperature and listening less than I did when I was getting used to it.) If you're going by sound, then 2C is 2C. But, if you're going by temperature then perhaps your setup has a malfunction and is reading too low. Thus, your degree of roast is much darker than anticipated, leading to the appearance of immediate oil. This might also bear on Jim's comment about too high an ET. Your ET may be higher than what's being displayed on your readout.
- Carbony/ashy could be due to the same thing. With the degree of oil I imagine you are describing you may be getting close to a Spanish roast. I've only once gone there in all the roasting I've done, but those two words definitely describe the horrible taste in the cup (only time I've ever had to bin a batch). However, that may not be the only factor. Lack of air flow can impart a burnt flavour in darker roasts. When I go to Italian or French (rarely these days), I keep the air flow on high (Quests have crummy air flow) or my wife will complain that I've burnt the batch. Metallic taste, on the other hand, I have no idea about. I've never let my roasters get hot enough to know, but I wonder if a really hot roaster would impart a metallic taste; certainly, one can smell hot metal...perhaps one can taste it too.
- I also wonder about your cooling regime. If you are used to light roasts, then cooling may not show up as a problem if the cooling is too late or too slow...one would simply have a somewhat darker roast than anticipated. However, if you are, knowingly or unknowingly, flirting with something really dark, then slow or delayed cooling might allow the roast to coast into something Spanish (my apologies to the Latinos here...I didn't invent the term ).
That's all I can think of.
- yakster
I was thinking cooling too.
-Chris
LMWDP # 272
LMWDP # 272
Could it be too hot charge temp? Assuming your roaster have a large thermal reserve and you're charging at 210C (is your first crack around 190C?).
- cannonfodder
Air flow also helps. As you approach second crack there will be a very large increase in smoke. If you do not have adequate air flow you can end up with a 'smoked' coffee.
Lower your environmental temp, make sure your bean temp isn't flatlining on the graph (to avoid baking it out) , hit it w/ an initial higher airflow - gradually start lowering as you get closer to first crack (still retaining a moderate airflow) . Shoot for a shorter roast w/ an extended dev. time. You want to keep your coffee moving.
Hey Sam, yeh crack at roughly 192.samuellaw178 wrote:Could it be too hot charge temp? Assuming your roaster have a large thermal reserve and you're charging at 210C (is your first crack around 190C?).
Just dropping around the 218 mark with 25/30 Dev% but very little sweetness and clarity in the cup.
