hbuchtel wrote:Thanks all for the great nuggets in this topic!
I'd appreciate hearing some more thoughts about airflow. I've been reading a book by the Japanese roaster Taguchi Mamoru in which he suggests limiting airflow in the 'steaming' (ie drying) phase to even out moisture differences in the batch. Any thoughts on this?
He is using a 5 or 10kg drum roaster with adjustable air flow- his suggestion is to close the airflow valve to 1/4 during this phase, then open it up 100% to pull out the skin, then close it again to 1/4 until 1st crack.
Regards, Henry
This sort of thing is very roaster specific; any commercial drum roaster will have airflow control as a major way of controlling the roasting process, and in combination with adjusting the heat source will be the way that you control roast temperatures. Most people reading this thread will not have any easy way to control airflow with their equipment, so it becomes more or less moot for them. Exactly how to do this and when (changes to airflow) will be very roaster specific. I think it is impossible to generalize on this in a way that would be useful for home roasters.
It also depends on what you mean by "airflow;" are you talking about passive air flow, or active air flow, as in the case of a Hottop where you can change the fan setting during the roast? For the Hottop this would be very academic in any event, because the heating elements in the Hottop don't have the capacity to get through the "drying phase" with any speed, so if you were to increase the fan speed early on in the roast, this would extend roast times to the point where you risk baking the coffee or flattening out the roast.
ken
