Whale wrote:Wouldn't the release of vapor be considered exothermic?
As you stated the energy is stored in to heat moisture and when the vapor is released, the energy is released as well. This is an exothermic reaction. Is it not?
Sherman wrote:Jim's advice is sound, to be sure, but also take into account how your roasting setup is unique and may not register temps in lock-step with what is provided. IMHO it's more important to get consistent readings for your setup than it is to shoot for any suggested temperature target. If you are consistently hitting 1C at 375F regardless of bean load, regardless of how close you move the HG nozzle, then you know that's how your setup behaves. Plan accordingly. This is the double-edged sword of a DIY setup - there's a lot more "Your Mileage May Vary" involved, and experience will be your best teacher.
Also, bear in mind that it may take a LOT of roasts to get in the ballpark of "consistent" & "acceptable". That 8 lb. "sampler" pack? It'll be gone in a week. You'll be playing with bean loads, charge temps, ramp tweaks and so many other variables that can easily consume your first 30+ roasts. The DIY path is NOT for people who want immediate & good results. Consider the subjective tone of anyone who tells you that you can get "great" results "immediately" with a DIY setup. I continue to have a great time learning on my HG/BM and can produce results to my satisfaction (and have the ability to tweak heat input to play with profile times), but it's taken almost a year to reach this point and I've roasted, drank and burned through almost 60 lbs. of green, in addition to regularly calibrating my tastebuds against some well-regarded local roasters. Then again, I may be a slow learner.
*throws 2 pennies into the pond*
-s.
another_jim wrote:In practice, your measurements are some weighted average of the beans' temperature, the heating device's and the ambient air's. As long as the weighting and your roasting procedures remain consistent, you're in business. If you reposition the sensor, the weighting changes, and the new readings do not compare to the old (although they can be better).
another_jim wrote:On Ken's post: This is somewhat inaccurate. It's not about the professionalism of the roaster, but about the characteristics of the coffee. You can roast some coffees, for some uses, even on the poorest equipment. Harars, Yemens, and Brasils to a rolling second crack, or Indos to a Vienna or French roast, can be done with just about any roaster. Check the homeroaster's list from a few years back, and these will seem like the "best" coffees.
germantown rob wrote:I need to read this thread a few more times though it is not the funnest thread in the world, still it has great info.
There is so little out there to find on just basic profiles and at times I have wondered if men in black suits keep it that way. 2+ years with my Hottop B and some time with a point and shoot Behmor and a few hundred pounds of greens plus what ever I have been able to find here and there on getting the most out of my beans has been a great education. I am just a babe in the woods and yet I feel those that have great info hide behind the equipment issue instead of just giving info on how to get the most out of a particular bean or type of brew it will be used for. All equipment will have it's pros and cons and they will all behave slightly different from each other for many reasons but what does this have to do with getting the most from a bean if taking into account what the equipment is capable of doing.
germantown rob wrote:I will be getting a 1kg Diedrich or Topper this summer, now I will have the equipment and there will be no excuse other then me. Where are the profiles being talked about if I have the equipment? How many people are really going to spend close to 10k on their home roast setup? I really don't believe that the equipment makes the out come better, tons of pro commercial roasters prove this everyday. The small percent of pro roasters that take roasting to it's extreme still are in business and need repeatability to keep their customer base, a home roaster only has to please a few mouths. So after I get my new equipment can I only speak to those that have a Topper or a Diedrich about what they do? I just don't buy that.
happytamper wrote:Dear Ken,
Home-barista is a fantastic source for information and has helped many people in their hobby however serious they are. I find many of your comments, in a number of threads, negative and/or condescending and thoroughly unhelpful. Though it is fun to see a guy like you go over the top at times and makes for interesting forum reading, I think many of us would prefer comments that are encouraging and constructive rather than unsupportive and elitist.
Sincerely,
A home coffee roaster/barista.
Mitch
