www.baratza.com: skilled in the art of grinding
Home Roasting: A Self-Assessment
Postby Martin on Thu Aug 05, 2010 5:11 pm
Here are 5 categories that affect my becoming a pretty-good-but-not-great home roaster. Each category means something unique to me, and I could go on at some length on each. But won't. I would also entertain others' categories or a re-working of these. In other words, it's a work in progress. Try your own.
I was moved to this scale by a recent post asking whether it was worth moving up from roast-method X to roast-method Y. Each of the answers seemed to leave out elements that would make a new roast method better, or simply be a multi-hundred dollar bother. With a max of 20 points per, I've rated myself here:
Knowledge (11 points): This includes all the stuff about coffees, chemistry, history, roasting that could be teased out and internalized. There's too much to hold onto.
Discipline and time commitment (10 points)
: I'm a slacker here. Roasting is an aesthetic experience and entertainment that also results in good espresso.
Experience (15): Maybe generous, but I've been doing the same roasting, same method, for many years. OTOH, I have only the most limited experience with other roasters.
Cupping ability (12): IMO, the most crucial factor. Probably sets the upper limit on roast quality over time. You can only work with what you can taste.
Control of Roast / Equipment (17): A few bonus points awarded here because of the good match between this and the other categories. I'll allow for the possibility that a high-end sample roaster (had I the facility) would inevitably push up the other categories, but I've seen nothing compelling that would lead me to that conclusion.
Total score: 65/100
Recommendation: Don't change anything. Pay more attention.
Martin
Postby another_jim on Thu Aug 05, 2010 6:23 pm
If I could find a sensible way, I'd add wonder/novelty/uniqueness as a category to this and most other things.
The trap of experience is that everything becomes like something you had before. At some point, people can get so experienced that they entirely miss the unique aspects of a thing, and everything becomes just like something else. For professionals, some completely new windfall, like the Geisha, which even the most jaded person can't dismiss as being like anything else can energize the market for years.
I think, once you're experienced, it helps to go looking for completely different and unfamiliar beans once or twice a year, even if they are ridiculously expensive. They won't be everyday coffees, but they can reset your perspective.
I'm looking to find something so different that I can knock down my self ascribed experience score form a 15 to a 5. :wink:
another_jim
Postby Whale on Thu Aug 05, 2010 10:04 pm
Following in Martin's foot steps...
Knowledge (8 points): Being very generous for myself. But I think that I have a lot of the theory (what I could find) read and "understood". I do not know what I do not know yet but I am sure that there is a lot!
Discipline and time commitment (15 points): I am pretty good on this. I want to learn and practice as much as possible. Beginner's enthusiasm...
Experience (5): Not been at it very long. Have not tried that many origins yet. Maybe 40 lbs, 8 origins, maybe 2 or 3 from each... None fully understood and optimised. And so much more to try. Only roasted on popcorn poppers so far. I know that my wife and I as well as most of my customers (family) like coffees on the bright side so the P1 is probably appropriate at this time, I guess.
Cupping ability (1): This I have to practice more or should I write I have to DO. I am not really good at identifying the individual components of aroma and flavour, other than the very obvious ones. I can sense them but I cannot yet separate them. I need to develop the skills to correlate a specific roast profile/process/parameters with the taste in the cup. Because I still prefer blends over SO, I am blending, with some success, by trial and error from the results on the espresso cup mostly. It is very hard (nigh impossible to correlate the roast parameters with the results. At this point I have achieved a fairly good balanced blend with a given set of parameters. Call it luck but now I can try different other things and still be able to get at 1 good cup of espresso a day.
Control of Roast / Equipment (10): I have stripped down, modified and rebuilt the P1 so many time that I could do it with my eyes closed. I have split the controls for the heat fan and the element power. I have installed ET and BT thermocouples. I am yet to fully understand how to use the ET data though. I have installed a glass roast chamber extension and a chaff collector with fume exhaust extraction. I data log every roast with power and fan setting notes. I now only and always roast 185 grams batches. Still, I feel that the control (or lack thereof) is still a work in progress. I'll package that with the lack of experience.
Wonder/novelty/uniqueness (20): Everything is a novelty to me at this point. I enjoy the variety and flexibility of roasting my own over purchasing from professional roasters. My results may not compare but they are good enough (thanks to my lucky blend) to sustain the learning process.
I guess this post will not help anyone else but it will maybe provide an explanation for my often naive comments elsewhere. It also helped me identify my next learning priority: Cupping!!!
I welcome any comments.
LMWDP #330
Be thankful for the small mercies in life.
Whale
Postby farmroast on Thu Aug 05, 2010 10:41 pm
After 5 years, experience wise I'm finally feeling somewhat at one with the beans and my roaster. With still plenty of room to tighten the relationships. Adding the BT RoR meter this year has made what's happening moment to moment much clearer and allows me more time to explore smells and sight without getting off course with control. Cupping/tasting and the ability to distinguish has greatly improved in the last year or so but being able to describe to others is still lacking. Excitement with roasting only gets stronger, I absolutely love it. Can't imagine not roasting my own beans. Still have a few types of beans yet to explore and am not in a hurry to use those new experiences up too quickly.
Ed Bourgeois
LMWDP # 167
http://coffee-roasting.blogspot.com/
"Bezzera Strega" the newest WMD in the LMWDP
farmroast
Postby Martin on Fri Aug 06, 2010 3:07 pm
another_jim wrote:If I could find a sensible way, I'd add wonder/novelty/uniqueness k:
When I achieve a fine and thoroughly predictable shot, I congratulate myself on consistency. :D When I hit upon the wonderful and novel, my first thought is to attribute it to luck or error. Something that's driven home by my little exercise is a greater understanding, even appreciation, for my espresso "style." No, I won't get into that - - -, but I'm sure it's something everyone has.
Martin
Return to Home Roasting
