JonR10 wrote:This is sad news for me....too bad it wasn't posted last week (that was when I bought one myself). Apparently these get warehoused in the Houston area and I paid $275 for mine, delivered. I have no idea when it will come, but it sounds like it will be an ornament rather than something I can hotrod for roasting.
Oh well - at least I know not to try it indoors!
I may still play with it some, but it sounds like a sure disappointment.
Jon,
Jim was convinced that it was a POS the time we tried to roast with it, but I proclaimed that our problems might have been due to "operator error." This would not be surprising, since there were no instructions whatsoever that accompanied the roaster. It took a second try to convince myself that the thing was in fact a POS, and that second attempted roasting session occurred today. I am one pound poorer of Ethiopian Worka as a result
This means that you are going to have a choice, not one that I would choose for myself. The choice would be whether you want to just let it be an objet d'art, or if you want to try to roast on it. If you choose the former, it will look pretty good in your living room. If you try to roast on it and decide it isn't worth the effort, the paint job will burn off (assuming they haven't found better paint in between our purchases) and although you could leave it in your living room, it won't look as good. If you do decide to roast on it, heat it up to a pretty high temperature for 15 or 20 minutes at first, without beans, because the paint needs to burn off before you can safely use it (if even then).
There is a third choice, which I'd actually recommend. That would be to try a dry run, without heating up the roaster. Charge the roaster with up to a pound of green beans, but with the roaster in the unheated condition. Preferably, use some old over-the-hill green beans you don't care about for this dry run. See if you can turn the crank without the beans flying out the trap door. You will need to turn the drum over a period of several minutes, at least, in order to establish this (assuming for the moment that there isn't something special about roasting beans vs. cool green beans that I haven't thought about). If beans start flying out the trap door and the turning of the drum itself becomes hard, then you are simply replicating my problems and I'd just empty out the thing and use it as a table ornament.
If on the other hand the thing turns smoothly and you have no problems, then you could try roasting with it. In that case it could turn out that my roaster was simply a lemon and that the basic design was sound (which I doubt, but I accept the possibility that I"m wrong, and I REALLY REALLY REALLY wanted to be able to recommend this product, so that would be good news from that standpoint).
In any event, please let us know in this thread how this whole thing turns out.
ken
