I moved the thermometer it came with to the opposite side, so that I could easily access the sampler. So, I think I'm getting a pretty good ET with that, since it's high up in and near the center of the drum away from the beans, especially if I keep the bean load down ( i only do about 175mg max loads) but now, I'm perplexed as to getting the proper location for accurate BT monitoring. I am weary about just sliding it thru the old hole from where the thermometer was originally located, since I am afraid air entrainment would throw off the temp stability and perhaps make it run hot? This is my main question. Can it be done this way properly? I haven't tried it yet and don't want to mess up good beans if I can prevent it.
Someone, somewhere, mentioned removing one of the screws down by the viewing window (circled in green), but when I did this, the glass falls right out. So that can't work.
I put a red dot where I think ideally, it would be perfect to drill a smaller hole, just enough for the thermocouple wire to fit thru, to literally sit right against the beans as they tumble, to the left of the left side screw ( ignore the red dot at the bottom, don't know how that showed up) . Has anyone done this? I have a drill, but not a drill press, and wouldn't want to mess it up slipping and scratching the surface.
I'm following all the recipes and guidelines here on the forum, learning how to use this. I'm not looking for a completely automated roasting experience. But I know being able to track BT and ET, will help me with reproducability.
Thanks all.
