This one has digital controls for both airflow and heat. Once the dryphase is finished, I turn this puppy on and it is like launching a rocket to the moon. You can control acceleration, speed, etc, which adds much more speed control to profiles as well as batch capacity.
It comes with two reducing tips, one big and one small. If you buy one, get the small one. The big one fits in the Q3 but the airflow is too big even at the smallest setting. The smallest restricts the airflow. A setting of 2 is ~ what I was using in my previous heatgun. A setting of ~700F is a good start (temp will drop with distance from tip).
You would also need a 1/8" X 3/4" x36" piece of aluminum from HomeDepot. You need to bend it at the edge of a table (round edge). Then cut the length.
The benefits are huge in terms of flavor. I know that it breaks the idea of a "perfect roaster" design but it gives the extra punch. Basically you end up with the most controllable roaster.
For best results, get the thermocouple adapters from Eric and a two channel thermocouple logger (to plot the profile in a computer). Once you try the results, there is no way back
Cheers
