Apologies to kupe - didn't mean to throw a spotlight on you.
I started with HG/BM based on info found on another forum and based my setup on seedlings, who posted above. Current setup is:
- BM rewired for continuous agitation. Original stirring paddle.
- Fiberglass insulation between basket & outer housing
- Heat controlled by plugging HG into router speed control
- Concave metal lid w/sightglass removed. Hose clamp on HG snout, foil wrapped around hose clamp
- Piece of pantyhose covering HG intake to prevent chaff inhalation. Fringe benefit is that it looks swank.
- Type J TC drilled through outer housing & basket, monitoring at ~1" up from bottom for BT
- Type K TC drilled through lid, monitoring ~3" down for ET
- Typical Load: 350g
- Typical Drop-in temps: 400F measured at BT
I've tested 100g-500g loads and drop-in temps from room temp to 450F, and found 350g with 400F BT sensor to be the best balance of quantity and responsiveness for my setup. At 350g:
- BT turnaround at ~235F at 1:00-1:30
- "Yellowing" ~285F BT at 3:00-5:00, dependent upon heat input
- 1C ~360F BT starting at 6:00-8:00, dependent upon heat input
- 1C duration up 90-150sec, dependent upon heat input
I still need cobble together and post the data output from my competition roasts, but I'm finding that, regardless of bean, I can get a 350g load to behave in a fairly consistent manner - turnaround at 1:00, yellowing ~285F at 4:00, 1C starting at 7:00-7:15, lasting up to 2 minutes, stopping at 3-4 minutes after beginning of 1C to produce FC roasts.
One continued source of frustration has been my own ignorance of how to take accurate measurements, how to correlate the measurements, and how to affect change. I'm not even sure that the ET probe is worthwhile, but would rather have too much data than not enough. I'm using the TCs as much as I'm using my eyes, ears and nose to tweak roasts, but there is hope.
I've found one single exercise to be immensely useful as a way of learning both how to use my roaster and how to train my palate. (
By no means do I make any claim about the completeness or correctness of this exercise, but it has proven to be a great tool for me, so I'm sharing it. Take from it what you wish, and feel free to provide corrections/updates):
Necessary equipment: notepad, paper, timer with resolution of minutes & seconds
- Pick one bean, preferably one from a known source that has been cupped by an accepted authority (that is, whomever you believe to have sufficiently-developed abilities with respect to cupping) and pick one load
- Given some basic guidelines (turn at 1:00, yellowing at 4:00, 1C at 7:00 in my case), try roasting a batch to the end of 1C and stopping there, modulating your heat so that 1C lasts roughly 90 seconds. If you can't meet those guidelines, change your load until you can. Record your results. Also helpful - what are you smelling at these various points?
- Keep roasting batches until you can determine and follow that profile, within reason (+/- 15 sec.)
- MOST IMPORTANTLY, cup your roasts. Don't know how? CoffeeGeek, CoffeeCuppers.com, and even Home-Barista give you a starting point. Try cupping 3 at a time. Compare your tasting notes those from item 1. Are you tasting the same, similar, or completely different notes than what is listed? Are you tasting consistent notes across batches?
- Keep doing this until you can consistently taste similar notes across all of your cupping batches for a given tasting session.
Congratulations. You've just learned how to do a consistent roast. The goal here isn't great tasting coffee, it's
consistent results. Once you can repeat your results, you can start tweaking. "Great tasting" is completely subjective. "Consistent" isn't.
-s.
Your dog wants espresso.
LMWDP #288
