seedlings wrote:You said your drying times couldn't be faster than 5:30 with a 500g load. Are you referring to yellowing or a specific bean temperature? I generally take 4 to 7 minutes to get the beans to yellow at 300F.
By drying times, I meant "the time at which I observed a color change from green to light yellow, consistent across the bean load". My measurements show this happening around 285F consistently, and as far as timing goes, I can nail it at 4:00-4:15 with the 350g load.
What I do know is that it is very consistent and predictable from roast-to-roast.
Can't ask for more than that. IMO, consistent trumps accurate for the purposes of this discussion. I've struggled somewhat with temperature measurements; while I'm consistent, I'm not accurate. I need to experiment more with probe location - thanks for showing your probe placement; it gives me ideas on how to proceed.
Are you intentionally varying, or is this more incidental? Have you tried doing side-by-side cupping comparisons? How do they taste? I've done some comparisons, but only from 4:00 to 5:30, and for the same beans, I could taste a slight difference. I need more beans for experimentation!
Thanks for the info. This is the detail that I've been craving, and I appreciate someone else blazing the trail.
-s.
