Greens Alert - Page 55
another_jim wrote:I'm roasting SM's Kela Kochere. Not much like the description except for the snappy acidity. Instead, I'm getting both savory and floral notes, as if it were a blend of Ethiopian and Kenyan coffees.
Ditto that. I've roasted this one every which way, and just can't crack it. Jim's description is spot on. I've hit up against this with other washed Ethiopians from SM's as well. It's puzzling, because in general I find their notes to be right on the money. Maybe these coffees just don't play well in my Quest.Roasty wrote:I'm glad you said this. I just had my first cup a few hours ago and thought I must have botched the roast because it tasted nothing like I expected from the description. I feel what you described nailed it, and I'm glad to know that I just need to change my expectation.
- EvanOz85
Good to know Evan. Your profile very closely resembles my most recent attempt, primary difference being about 20 more seconds of dev time on my end. I'll take another crack!EvenOz85 wrote:Hmm, odd. I roasted the Kochore very fast and found the tasting notes to be quite similar to SM's.
- rama
A Colombia Gesha and 2 Ethiopia dry processed (for those who like that sort of thing...) are available now:
http://legacy.sweetmarias.com/library/node/9471
I'm looking forward to this Keffa Sidamo Ardi that should be arriving very soon:
http://leverheadcoffee.com/index.php?op ... Itemid=552
It sounds delish
http://leverheadcoffee.com/index.php?op ... Itemid=531
It sounds delish
If that's the same Ardi that I bought from GCBC earlier this year, then it's fabulous. The description on the leverhead site is spot on; strawberry all over this one. Ethiopian greens are thick on the ground at my place right now, but I'm tempted to get more of this stuff. Really satisfying.
Excellent.
I've got 5# on the way from Leverhead
http://leverheadcoffee.com/index.php?op ... Itemid=464
Larry used to be one of my favorite sellers at G**** , but he doesn't sell there anymore and I'm no longer a member there, so I don't know if it's the same or not.
- NoStream
I had a chance to roast up a batch of one of SM's new dry-processed Yirgs last night, the Buufata Konga ( https://www.sweetmarias.com/product/eth ... fata-konga ). I roasted it pretty much the same I would a washed Yirg, just with a bit cooler of a charge.
I highly recommend it - super clean and sweet fruits (strawberry, lime), plus the florals and tea-like character of a washed Yirg. The balance of processing and varietal character is spot on, and there's no fermenty-funky-fecal thing going on at all; this is cleaner than plenty of washed coffees I've worked with. The processing left the acidity pretty intact - often an issue with DP coffees - and there is tons of sweetness as well.
(150.0 g charge, 12.0% WL, city finish)
- MSH
Roastmasters just got in some Yemen Haraaz Special Red Grade A+....
http://www.roastmasters.com/yemenred.html
Klatch now has the Panama Elida, both natural and washed
http://www.klatchroasting.com/Green_Eli ... li_nat.htm
http://www.klatchroasting.com/Green_Eli ... li_was.htm
LMWDP #556
Life is too short to drink bad wine - or bad coffee
