by another_jim on Thu Jan 07, 2010 5:54 pm
Roman is right on most his points; but if I remember it right, I think good heat gun roasts generally tend to take longer than drum roasts. Hope someone with experience in the method will chime in.
In an extended cool roast, the sugars will caramelize, and the beans get darker, even if they never hit the first crack. This is what Roman meant by baking. A baked Sumatra will be very "foresty" tasting, I think.
Most Sumatras taste a lot better in a rolling second crack roast than earlier; you should focus on getting your beans that hot. This means you should be getting a lot of oily smoke and rapid crackling as you end the roast. You should be shooting for at the most 20 minutes to get there. If you can't get the beans to that roast color in that time, you will need to roast hotter and/or cut your load.
I'm not saying you should roast everything that dark; but you're doing something wrong if you cannot get any roast that dark.
