Hi Jim,
Thanks for the input!
another_jim wrote:From your profile graphics, it looks like the Gene operates more like an air roaster than a drum roaster. In which case preheating may be pointless.
It took me some time to understand the physics behind the GeneCafe. I think it is a combination of an air roaster and a drum roaster. It has a rotating drum.....with hot air passing trough it.
There are a couple issues I'd like to address at the moment.
First: The "strange" convex profile of the graph.
The temperature measured by the roaster it self (and displayed), is actually the air temperature at the exhaust of the roaster. When the roast is started at ambient temp the roaster itself has to heat up. The air at the input of the drum is hot, the roaster itself is cold. Energy which is put into heating the roaster can not be put into heating the bean. Thus pre-heating the roaster should help.
Second: What is the bean temperature?
The temp. displayed at the GeneCafe has definitely nothing to do with the bean temp. So I guess the best thing to do with this roaster is to take the internal and surface bean temperature form literature. Sure it's different for every coffee and it's not very accurate, but it is definitely more useful then the air temp at the exhaust of the roaster. Now all you need is the time the first crack starts and you can calculate an average bean temp slope.
To see if I could influence this slope I did an experiment. You can read about it
by clicking hereBasically I did 2 roasts. One starting at ambient temp and setting the temp at 235 deg (455 F) and one pre-heating the roaster at 250 deg (482 F) and keeping it at this temp until the start of the first crack. Then lowering is to 235 deg (455 F).
In the first roast the first crack started at 11 min 30 s and in the second at 7 min.
I assume the internal bean temp at the start of the first crack is 185 deg (365 F) and surface temp 205 deg. For the first roast the internal bean temp slope is 16 deg/min (61 F/min), the surface bean temp slope is 18 deg/min (64 F/min).
For the second roast the internal bean temp slope was 26 deg/min (79 F/min), the surface bean temp slope was 29 deg/min (85 F/min).
I know this is not very accurate information and it is an average temp slope, but I think it is the best you can do with an unmodified GeneCafe.
Question for me now is: What is better, the 'slow' slope, or the 'fast' slope. The answer to this is of course that I have to taste the difference. I tried a cupping session last weekend, but that was also my first and very difficult to taste the difference (I think because of inexperience). Maybe you have some advice on the temperature slope?
I don't think I am ready to stop a roast by smell. Sure I smell the smells. But it is still a bit difficult to distinguish them.
Again I appreciate any input. I consider my self as a roasting rookie and want to learn!!
Regards
Edwin
