by bean2friends on Thu Sep 09, 2010 3:56 pm
Thanks again. This whole process has probably revealed some of my character defects. First, I try to reinvent the wheel by using my own terms. I'll try to do better at using terms others use. And, secondly, I was impatient. So, I'll address the impatience first. When I noticed this aroma issue, I started roasting several different kinds of beans. I roasted 8 oz. batches in my 1 pound drum on my rotisserie and I roasted 1/2 cup batches in my 2 poppers - 1 a 1200 watt Toastmaster and one a 1400 watt Wearever Popcorn pumper. The Panama beans I roasted in the 1200 watt popper from a cold start. I got 1st crack at 5 minutes, stopped roast at 7 minutes, infrared thermometer reading of 430 degrees. I thought it looked like City+. I followed this with a second roast in the same popper. Got 1st crack at 4 minutes. I stopped this roast at 5 minutes, 50 seconds at what my infrared thermometer showed as 425 degrees. I thought this would be a City roast. In fact it looked the same to me as the 1st roast - a little darker than I thought City should be. I did these roasts on 9/4 and until today these roasts did not smell good to me. Today, they smell better. So I think the resting has helped. Although, I went down to the local grocery that carries Intelligentsia beans and picked up a bag of 5 day old roasted Central American beans. These helped me reset my aroma senser I think. Now I think they smell like smoked raisins. And a little like smoked hershey's dark cocoa. (I also stuck my nose in a container of that to help my point of reference). Although, I do suspect these roasts took a little long to get to 1st crack and that preheating the popper might help. Do you suppose that I just don't like this particular coffee? I'll taste it again tomorrow to see if the taste has advanced along with the aroma. Another question I have about aroma of coffee as it relates to taste is: Can it be like cheese? I mean can the aroma be off putting while the taste is enjoyable?
The Liquid Amber I was concerned about I roasted in a 1 pound drum on my Weber Spirit grill. I roasted this on 9/3. Here's how I did it. I preheat the grill - not the drum. I used 2 thermometers - the Weber that's on the top of the grill and a digital that I got from Sweet Maria's. I position the thermocouple on the digital so that it's at the level of the beans in the drum although obviously it is outside the drum.
So when the Weber read 380, the digital read 470 I loaded the drum in the grill. I was back to 500 degrees on the digital within a minute after loading. At 5 minutes I had good sweet smelling aroma from the grill and showed 440 degrees on the weber and 570 on the digital. 1st crack started at 12 minutes, 15 seconds with 440 degrees on the weber and 585 on the digital. At 13m 15s I showed 450 on the Weber and 600 on the digital. I turned the gas down slightly at 15minutes. at 16m 45s I showed digital temperature of 530. I I I think I started second crack at 17m 30s and stopped the roast. I had pretty good smoke and the roast looked like a pretty even light Vienna. I was pleased at that time. But after 3 days, it didn't smell sweet or caramely or chocolatey it smelled like that bar room where people had been smoking all night - maybe like an old ash tray, maybe a little like leather - an old baseball mitt. And it had a harsh taste dominated by that old ash tray smell. Today though, it smells sweet and made a great espresso with lots of crema and tasted mainly of bittersweet chocolate, and, of course, some smoke.
So, I've learned to wait a little longer. But also in addition to warming up my popcorn poppers before a roast, for my grill, I'm thinking I should try to finish my roast in 15 minutes. So my plan is to preheat the grill to 475 on the weber thermometer, which will probably be around 650 on the digital. I would expect 1st crack then in somewhere between 6 and 10 minutes. Then after 1st crack, I have read some different recommendations, but I'm thinking I should try to slow down the move to 2nd crack so I'll reduce the temperature but try to finish in less than 15 minutes.
