Let me guess ... Monkey Blend?
It's hard to tell much from a photograph except warning signs. If this is a blend, two of the warning signs -- uneven colors and some white and some dark splits -- are moot (if it isn't a blend, but just a dry process, you blew the roast by not gettting it out of the first crack; if it's just a wet process, then it's so weirdly wrong that I'm stumped). Otherwise the beans seem unwrinkled and fully expanded, so that part is fine.
WARNING: if you pull an espresso immediately after roasting, you will die horribly
One of the perks of homeroasting is you can find out what happens to coffee as it ages. Try it now, try it later, taste it for yourself.
