Gismar wrote:When I check the internal development at 300F, the bean is not 100% dried, should it be 100% finished at 300F? Or can the drying end as late as 320 F/160 C? Im roasting on a Diedrich Hr-1 roaster, wich can give longer roasting times than normal. At this roast My start temp is 340 F/170 C, and spend approx. 7,5 minutes to 300F.
A shot in the dark here... I'd suggest a higher starting temp, so that it gets to 300F more quickly, but then try to hold it there for ~3min. Depending on the moisture content, 3min. may not be enough, but that's my average hold time. I always look for a color change before leaving the 300F hold point, that it's gone from green to yellow/golden.
Generally, 1st crack starts for me around 400F, obviously different for different beans. But this tells me that your 300F reading and my 300F reading are not the same. You may want to hold yours for the drying phase a tad lower, perhaps 280F, and then watch for the color change to yellow/golden.
The problem with moisture remaining in the bean is that it compromises and conflicts with some of the chemical reactions and will produce unwanted compounds and flavors.
