docdvm wrote:...The iRoast can only roast 150 gm at a time and only once daily.
Hey doc
I have 2 of the ''beasts'', and I assure you that you can do back-to-back roasts till the cows come home with no negative repercussions, overheated units or consequences
(other than more coffee). I've been roasting in a pair of them for 2 years now, and routinely do 4 roasts back-to-back-to-back stopping long enough to dump the chaff, re-select the profile and hit ''roast''.
I roast by 1/2 cup measure, not by weight, but I'm guessing I do more like 170g per batch
(depending on the bean of course). One of my unit's fan is stronger so it's load is a little bigger, the other I do 1/2 cup minus one layer of beans.
I have been roasting 1.5 - 3 pounds a week for 2 years with them and the pair of iRoast2s were a vast improvement over three Fresh Roast units all going at the same time
(each on it's own circuit and each on a Variac).
I like the iRoast2s, but they are noisy devils. I don't count on hearing 2nd crack, so I wear earplugs when roasting with them. I use both at the same time all the time, and two of them on my workbench are able to generate some decibels. I use my eyes (and a bright flashlight) and my nose to know when beans arrive at the point I hit ''cool''...
You can promote better cooling and create a longer break between first and second crack by opening the little screened-lid on top. I know where the break is programmed on my profiles, and backing down the temp and opening the lid is how I back them off for space. Trust me, they recover from 320°F to 405°F in less than a minute once I retighten the lid and the new profile (from 350°F to 400°F) kicks in.
It spews a bit of chaff depending on the bean, but I'm in a garage working on the workbench and my handy-dandy shop vac is right there to help clean up. You can even nudge the bottom section of the lid over for extra cooling. That small a load of beans reacts to temp more quickly than a drum roaster.
I also always loosen both lids
(not remove, just loosen) during the cooling cycle and the beans are close to room temp at the end of the cooling cycle...
I have drilled 3 half-inch holes in the center of the chaff collector so more air vents during roasting, and I make sure the screen in the top lid is very clean since it will build up too much heat if it gets plugged tightly. These babies really get up and move when they are going full force (over 400°F).
If you have not roasted with an air roaster, the rule of thumb is more-beans more-mass more-heat quicker-roast
(until you choke the unit or overheat it with too big a mass of beans) and vice versa less-beans less-mass takes a bit longer. If you want them to roast quicker use more beans - but you must not exceed the roaster's ability to keep them churning and you must not get such a large mass of heat that the heat builds up & trips the thermal overload.
The LCD is useless for knowing actual temps, and it is merely a good guide. I have several profiles for different beans and conditions in mine, and I reevaluate and modify them fairly routinely. No one profile fits every bean or weather condition.
Hope this is not wasted info (you may very well know all this already). I'm pretty intimate with my pair...
I'm hoping when the Behmor gets here it will give me bigger batches with less noise and more uniformity.
