The weather is getting cold and opening the window all the way is not an option. This is a very easy mod (10 mins $15) on how to fabricate an exhaust for the Quest M3 roaster.
First you need the materiasl. I got then at HomeDepot for $15. I think they are made of galvanize steel. They are strong and easy to clean (smooth surfaces).
Then you need to notch the 4x3 reducer with aviation shears (or a pair of snips) and bend the edge out. To fabricate the flange, you need to put the square piece (flange) aligned with the exhaust hole of the roaster and bend it (make a hanger for the top). Then cut it. Make sure you place the flange in a diagonal so that you have enough length to reach both edges of the roaster (it will hold it in place). Bend the edges and make a small hole for a screw in one side. This will prevent the weight of the exhaust from tipping to the side.
Finally, connect the pieces together and enjoy.
