Important good finding for owners of Quest M3 roaster
This is more about the intake than the exhaust. I got very good heat transfer using the fan all the way. However this requires a warm air ambient temperature like 70F. If the room temperature is 60F the heat transfer by convection is very poor.
Now here comes the trick. You can get super high heat transfer at 60F room temperature too! If you put a kitchen towel making a semi circle around the intake hole, you create a micro climate that reaches 78F even when the room temperature is 60! My measurements of delta BT are super high and the heat transfer is very high. This will allow to roast very sensitive (low density) beans at very low MET in semi-cold room temperature. You could also use this trick to increase the charge (load) while keeping a fast roast time. Don't block the hole! Restrictions in the hole decrease the deltaBT. The more air it gets the better, but make it suck the air from the direction of the drum/walls.
Here is my picture. As you can see, if doesn't have to be in a neat arrangement. If you want, you could play with the towel till you get a a max reading in the micro climate area using a thermometer. Roaster needs to be already warm.
Regards
EDIT: During an actual normal roast, the air intake temp will reach the 130Fs in the microclimate area with ambient temp of 67F.
