rennix wrote:I used between 1/3 and 2/3 cup, closer to 2/3. Didn't weigh.
There are limited variables that I tried to quantify above as an example.
Big concept: You are looking for the sweet relationship between bowl size , batch size, and air temp that gets you to 1st c. in close to six+ minutes. This time is not written in stone, but you've got to have target parameters when you begin the roast. That means after you choose the bowl, weigh the beans. Because if you don't, you lose control over one of the few variables available to you. If your roast takes 10 minutes to 1st, drop your batch size by an ounce or two.
It also means that you need a timer or a watch----not to get all compulsive over seconds (that might come later,) but watching the minutes as the roast progresses is very instructive for lots of reasons I'll not get into here.
As 1st c finishes, or nearly so, you will have very slightly backed off the heat. You don't want to rush into second, so don't needlessly worry about stalling the roast (when there is too little heat to keep the roast from progressing.) Again, watch the time (and color, and smoke and smell.) If you are into the 10th minute, you can force the roast into FC+, some 2nd cracks, which is a good place to stop these early roast attempst.
Keep the HG at the highest power. The only heat variable you want to deal with is distance from the nozzle to the beans. Fiddling with the temp just complicates things. An underpowered HG takes away a lot of control. It's not fatal, but it matters.
