Elegant bean probe setup for Hottop
Postby ElBean on Sun Mar 23, 2008 3:49 pm
I used a brass rod, 1/2" dia and turned it down to 7/16, (except for the tapered head), Threaded it and bored 1/8 hole to accept the thermocouple. I cross drilled and tapped 1/8 hole for a set screw to secure the TC after protrusion adjustment to just clear the arms of the drum. The thermocouple wires were attached to a mini recepticle mounted to the back cover.ImageImage
Regards,
Elan
ElBean
Postby cafeIKE on Sun Mar 23, 2008 5:51 pm
Care to log and post a temperature comparison of the HotTop readout and your probe temperatures?
Two issues I see :
1. The insertion depth should be about 10x the probe diameter.
2. The probe mount may affect the reading.
Here's a comparison for my 'old' digital HotTop:
cafeIKE
Postby ElBean on Fri Mar 28, 2008 9:36 am
Ian,
I spoke with the brains at Omega. They assured me that my installation is fine for the intended purpose and any mounting induced errors ( which are always present) will be very small, (0.5 deg F or less).
My roasts are done manually and I use the the probe readings to help me develop a profile. I am more concerned with repeatability then an exact temp reading.
Regards,
Elan
ElBean
Return to Home Roasting
