Coffeengineer wrote:I have a suggestion that I am trying with some apparent success: when a greens shipment arrives i drop one of those RH/temp panel meters into the beans and seal them up in my 16C constant temp wine cellar. After 1-2 days stabilisation of temps & RH the meter reading for relative humidity gives a rough guide to moisture content - enough to adjust phase 1?
Just an idea given that green beans will take up in humid environments and lose in dry... is it worth developing? No doubt the actual number is bean and temperature specific.
Quoting myself, sad. No one took this up... definitely the fastest and a quite accurate method of measuring moisture content. What one needs is the sorption isotherm for green coffee beans in question for the measurement temp. Don't know how they change with temp. Measurement only takes 5 mins and requires no heating... I found a sorption isotherm for green coffee at 20C (variety not specified):
The x axis is equilibrium relative humidity (ERH).
Does anyone have access to one of these
machines? It takes 24hrs to generate an isotherm that can then be used for rapid moisture content readings.
Now that I have sourced greens from different locations I am measuring ERH in the range 48% to 72%, certainly gives one a hint as to how long the drying phase should be.
Eric
ed: ERH (ratio of water mass in air) and water activity (ratio of water vapour pressures) are technically slightly different.
