www.ajcoffeeco.com: excellent coffee without compromise
Drums with metal finishes are a poor choice for thermal radiation - Page 2
Postby Arpi on Mon Jul 04, 2011 12:47 pm
Hi DJR.
I think that keeping a shiny outer shell would be helpful. The one you need to watch would be the drum.
I have found an easy way to raise the emissivity. I was lucky that my drum was already internally dark by usage (oils). Following the same principle, I decided to lightly sand the outer wall with 300 sandpaper. Then I applied a thin coat of cheap vegetable oil. I put it back on the roaster, and I let it burn the oil at 550F ET. It took ~ 45 minutes before I could not see any white smoke come out any more.
This is a before and after:
Before
Note above: see how dark the internal wall is
Note above: see the new dark color developing.
I decided to take the drum out and now I am going to apply a second coat of vegetable oil and let the roaster run ~ 1 hour
Cheers
Arpi
Postby Arpi on Mon Jul 04, 2011 3:08 pm
yeap. It makes a difference. I did a sample roast and the first crack came out like from a machine gun. The second crack was also very loud and fast. It never was like this.
This a 300 gram roast of Kona beans.
Note above: I also use a heat gun after Dry End till 1C, but I can tell you I never got high crack speeds till now.
This is how the outer wall of drum looked after the second coat of oil
Cheers
PS: At a stable ~ 550F ET, the heater elements don't emit any visible light. It is probably all mid-long wave infrared and convection.
Arpi
Previous
Return to Home Roasting
