by kocurekc on Sat Jan 15, 2011 8:35 pm
Good engineering thought problem here...which material is best?
What is best from a "Temperature Standpoint"
Mat:............Density...........Specific Heat...........Conductivity
..................(kg/m^3).........(J/kg*K).................(W/m*K)
Stainless.......8000...............460.......................13.5
Carbon S.......7800...............470.......................43
Cast Iron.......7200...............420.......................52
Densities are a wash, but cast iron would be the lightest
Specific heat is a wash, but cast iron takes the least amount of energy to heat it up
Conductivity is interesting though, stainless steel is going to "hold" it's heat the longest and will take the longest time to get hot. Cast Iron will heat up the fastest and will also let go of its heat the fastest.
Conclusion (IMHO):
If you want to have quick (or quicker) changes in the temperature of your drum (i.e. one temperature ramp to another temperature ramp) and you have good control on your heat input, then cast iron would be the best choice.
If you want to have a consistent temperature (or temperature ramp) with only modest changes in slope, or you have poorer control of your input heat, then stainless steel would be a better choice. This is due to the fact that the stainless steel will not fluctuate as much as the other material (given the low conductivity) as the heat source changes (Q).
That's why they don't make stainless steel brake rotors...once they get hot, they stay hot...
