Diedrich One Pound Roaster? - Page 2
Postby swines on Wed Apr 09, 2008 9:30 am
Richard wrote:This thread, Diedrich Home Sample Roaster; reflections on larger home roasters, from about a year ago provides some reading on the subject.
Except the thread contains little real information as most of the comments are speculation and projection; and not based upon actual usage of an HR-1.
swines
Postby coffee_monkey on Wed Apr 09, 2008 11:18 am
swines wrote:The difference in use between this roaster and a gas fired roaster is the hysteresis associated with the temperature change due to the electric IR heating elements needing time to respond versus the instantaneous heat application available with a gas fired roaster. With a gas roaster, you have a "4-minute window," meaning what you did two minutes ago affects the roast now, and what you do now will affect the roast in two minutes from the time you've made the change.
The HR-1 has about a 5 minute window (2.5 minutes on either side of the change). So, you have to setup your roasting profile to the machine's response.
That is some serious lag time. On our gas-fire 1lb sample roaster, the lag time is about 30 seconds. Even on my primitive gas sample roaster (250g) in the solid drum format, the lag time is no more than 1 minute.
What model of gas roaster are you referring to?
- Ben
Ben Chen
coffee_monkey
Previous
Return to Home Roasting
