by another_jim on Fri Aug 27, 2010 5:52 pm
The temperature and bean color at which the cracks start and end changes as roasts get longer.
If you roast fast, the first crack, created by out gassing steam, starts at lower temperatures and lighter colors; while the second crack, caused by the breakdown of the cellulose matrix, starts at higher temperatures and darker colors. So, for fast roasts, there's a distinct gap between the end of the first and the start of the second.
If you roast slow, the out gassing takes longer, the first crack is less vigourous, and takes place at higher temperatures. The cellulose breakdown however, progresses at the regular pace, and the second crack starts at a lower temperature and a lighter roast color. So, on slow roasts, the first cracks runs into the second crack.
If you do not have a thermometer or tryer, it's much easier to get consistent results if you roast fast enough so the cracks are separated by a a couple of minutes quiet time. To do this on a Hottop, roast less weight or drop in the beans at a higher temperature (let the roaster run on empty after it dings for a minute).
