Custom built coffee roaster
Postby boom1 on Tue Mar 03, 2009 7:22 am
Hi guys
I am busy with a project where I am designing and building my own profile controlled sample coffee roaster. The project is quite massive and forms part of my studies for the next year.
I just have a few questions that I was hoping you might have the answer to:
- How big should the roasting drum be for about 1-1.5kg per roast? (diameter and length)
- What type of material is the best? Steel or stainless steel? Stainless is nice, but extremely expensive and requires special welding.
- How thick should the drum material be to be able to evenly conduct heat? It should be thin enough for quick heat adjustments.
- Does anyone have some schematics on a chaff filter? I'd like to build a simple cyclone based filter, but would appreciate some exact measurements.
Thanks guys. Hope you can help! I'll keep you updated with my progress
boom1
Postby farmroast on Tue Mar 03, 2009 10:53 am
Ed Bourgeois
LMWDP # 167
http://coffee-roasting.blogspot.com/
"Bezzera Strega" the newest WMD in the LMWDP
farmroast
Postby ValentinDavid on Tue Mar 03, 2009 10:56 am
I think if you want the exact answer you should do a simulation on computer. Maybe a bit of work to set it up. But once you have it, you can make the different variable to vary and see the result (thickness, material, shape, etc.).
ValentinDavid
Return to Home Roasting
